开源TypeC拓展坞,4个10Gbps的USBA口+2.5G网卡+读卡器,VL822+RTL8156BG+GL3224
Open-source USB-C Input USB3.2 Docking Station with 4 USB3.2 Gen2 Ports + 2.5G Ethernet + TF/SD Card Reader, Supporting PD Fast Charging for Additional Power Supply. Input Voltage Range: 4-20V. Buck-Boost Circuit Regulates Output to 5.1V. Based on VL160+VL822+RTL8156BG+GL3224 Chips.
Open-Source USB 10Gbps Hub with 2.5Gbps Ethernet & TF/SD Card Reader
:round_pushpin:This is my first time working on a high-speed PCB project. If there are any areas needing improvement or mistakes made, experts are welcome to provide guidance.
:rocket:Also actively seeking job opportunities online! Employers in Guangzhou/Foshan interested in hiring can contact me. Check my open-source projects on LCEDA: https://oshwhub.com/zeruns/works
Project demonstration & design process video: https://www.bilibili.com/video/BV145G1z9Em2/
LCEDA Open-Source Link: https://url.zeruns.com/U9sCt
QQ Group for Electronics/MCU Discussions: 2169025065
Download links for project files at the end of the article!
Project Overview
:play_button: This USB-C input USB3.2 docking station provides 4 USB3.2 (10Gbps) Type-A outputs (the input port is also 10Gbps, so the total speed remains 10Gbps), 1 2.5G Ethernet port, and TF/SD card readers.
:play_button: The 5V power supply uses a Buck-Boost circuit to regulate output to 5.1V (0.1V higher to compensate for line loss at high currents). Two Type-C inputs: one for data (also supports 5V power but not PD fast charging negotiation, connected to the Buck-Boost circuit to prevent voltage drop at high currents), and one dedicated power input (supports PD fast charging detection to trigger 20V input, then stepped down to 5.1V via Buck-Boost). The 5V power circuit supports up to 9.5A output current, with each USB-A port delivering up to 2A.
:play_button: Two VL822 chips are used. One VL822 has an unused USB interface that can be modified for additional features, such as adding another Type-A port or integrating a microcontroller with current/voltage sampling to monitor real-time power usage on all USB ports (planned originally but limited by PCB size constraints).
:play_button: The design uses a two-layer board: the upper board houses the 5V Buck-Boost power circuit and card reader circuit, while the lower board contains the USB HUB and 2.5G Ethernet circuits. Boards are connected via FPC and XH2.54 ribbon cables.
:play_button: Key chips used: VL160, VL822, RTL8156BG, GL3224, EA3036, MT2492, SC8703
:play_button: Inspired by this project: USB3.2 Dock with Independent Regulated Power Supply
Docking Station Specifications
  • Input Interface: USB-C
  • Output Interfaces: USB-A, RJ45, TF, SD
  • Max Input Speed: 10Gbps
  • Max Output Speed: USB:10Gbps | RJ45:2.5Gbps
  • Max Input Power: 5V@5A / 20V@5A
  • Max Output Current (Type-A): 5V@2A (total up to 8A across all ports)
  • Dimensions: 90 x 74 x 26.3 mm
Physical Photos
After installing the enclosure:
Power-on operation:
PCB details:
Lower board (front/back):
Upper board (front/back):
Hardware Implementation
When connected to a USB@5Gbps or higher-speed interface, the high-speed bus hardware architecture is:
USB signals first pass through the VL160 level-shifting chip for reversible plug detection, then to the VL822 hub chip which splits 1 USB into 4.
For 480Mbps interfaces, signals bypass the VL160 and connect directly to the VL822 hub, limiting downstream speed to 480Mbps.
Power Hardware Architecture:
The SY6288CAAC power switch includes overcurrent protection. When load exceeds 2A, the switch disconnects power and pulls the OC pin low to notify the controller.
Hardware Performance Tests
Type-A Port Output Ripple Test
Power Conversion Efficiency
Input Voltage(V) Input Current(A) Input Power(W) Output Voltage(V) Output Current(A) Output Power(W) Efficiency(%)
19.997 2.291 45.81 5.11 8 40.88 89.23%
19.998 1.122 22.44 5.15 3.999 20.59 91.79%
19.998 0.569 11.38 5.18 2.002 10.37 91.14%
4 2.839 11.36 5.2 2 10.40 91.58%
4 8.063 32.25 5.17 5 25.85 80.15%
PD Fast Charging Detection Test
Thermal Imaging
USB Interface Speed Test
Connecting the dock to a computer’s USB@10Gbps port and testing an RTL9210B-based external SSD via AS SSD Benchmark: Read 969.65MB/s, Write 912.65MB/s.
TF/SD Card Reader Speed Test
Using a Samsung EVO Plus TF card: Read 93.04MB/s, Write 20.13MB/s.
2.5G Ethernet Speed Test
Internal network speed test server shows: Download 2089Mbps, Upload 2497Mbps.
Replication Notes
  1. The enclosure is 3D-printed. 3D model files available in the download section at the end of the article.
  2. Enclosure screw holes require M2.5 heat-set nuts (installed using a soldering iron).
  3. When ordering PCBs, select JLC04121H-3313 stack-up, board thickness 1.2mm, and require impedance matching.
  4. Some systems may experience reduced Ethernet speeds. Install drivers from 绿联USB有线网卡-RTL芯片-全系统_UGREEN_EthernetAdapter Driver_V1.01.zip (available in the download section).
  5. Card reader speed issues may require firmware updates. Use the tool in GL3224 update tool v1.0 (factory firmware v1532, latest v1539). Flash chip can be omitted if no update needed.
  6. Both 30-pin FPC and 6-pin XH2.54 cables must be reverse-assembled.
M2.5×8×4 Heat-set Nuts
Schematics
Upper Board
Lower Board
PCB Layouts
Upper Board
Lower Board
Component Purchase Links
Most components used in this project are available here:
English Version of the Article: https://blog.zeruns.top/archives/53.html
Do the 3.3V and 1.0V pins on the VL822 chips need to be externally powered or just linked together? I have seen conflicting things, some say that the chip has onboard LDOs that step the voltage down and those pins just need to be tied to ground via a capacitor but it seems like you are supplying them with external 1.0 and 3.3V power?
I would appreciate any help you could give :slight_smile:
Hi! For the VL822 chip, the 3.3V and 1.0V pins do indeed need to be externally powered.
While some older or lower-speed USB hub controllers feature integrated LDOs or DC-DCs (where you only need to tie the pins to ground via a capacitor or inductor), the VL822 is a high-speed USB 3.2 Gen 2 (10Gbps) chip, which inherently consumes significantly more power.
Providing power via external DC-DC step-down converters (like the EA3036 PMIC used in this project) is the standard and necessary approach for a few reasons:
  1. Thermal Management: 10Gbps hubs generate a lot of heat. If the chip were to step down 5V to 1.0V internally using an LDO, the power dissipation would cause severe overheating, leading to connection drops or speed throttling. External DC-DC converters are much more efficient and keep the main VL822 chip cool.
  2. Signal Integrity: 10Gbps data transmission requires extremely stable and clean power. Dedicated external power rails ensure lower voltage ripple and sufficient current delivery, preventing data errors under heavy read/write loads.
So yes, you cannot just link them together with a capacitor; they require dedicated external 3.3V and 1.0V power supplies to function stably. Hope this clarifies things!
