Be clearer: what power topology is this?
Also provide the schematic, otherwise there’s no way to know where that 0.2-ohm resistor you mentioned is…
It’s just the 72W flyback you open-sourced, blogger ![]()
After the 0.2R resistor blew once, did the VCC waveform become like in the image above?
Check whether the primary switching transistor is damaged.
After winding the transformer, did you measure the parameters with an LCR bridge? What are the primary and secondary inductance values and the leakage inductance, and was the core tightly wrapped with tape?
