Compiled from my recent study notes after picking PADS 9.3 back up—a follow-up to my earlier shortcut compilations for JLCEDA, KiCad, and AD (topic 427 / topic 428 / topic 429), this time with PADS as the subject.
Applies to PADS 9.3 / 9.5 (the 9.x era under Mentor Graphics); menu names follow the English UI, with key terms given in Chinese. It assumes you’re already fluent with JLCEDA Pro or KiCad, so things like “what is a schematic” are skipped entirely—only the places where the two worlds diverge are covered. Key bindings are all defaults and can be changed under Tools > Customize > Keyboard and Mouse.
1. Accept one premise first: PADS is three programs
PADS 9.x still has a substantial installed base in China’s power supply, consumer electronics, and industrial control industries; plenty of small and mid-sized companies still treat it as their standard workflow, so you may run into it when taking over an old project or joining a new company.
The biggest difference from every modern EDA tool you’ve used is that a single design is split into three separate programs, with the netlist passing data between them.
| Program | Main file | What it does | Equivalent you know |
| PADS Logic (formerly PowerLogic) | .sch | Schematic, ERC, BOM | JLCEDA schematic / KiCad schematic editor |
| PADS Layout (formerly PowerPCB) | .pcb | Placement, routing, rules, copper pour, CAM | JLCEDA PCB / KiCad pcbnew |
| PADS Router (formerly BlazeRouter) | reuses .pcb | Interactive routing; push-and-shove and obstacle avoidance are better than in Layout | A souped-up version of KiCad’s interactive router |
Layout and Router share the same PCB database and you can switch between them at any time. For getting started, Logic plus Layout is entirely enough, but you should know that PADS’s push-and-shove routing is only complete in Router; the one in Layout is a simplified version.
The schematic and PCB are kept in sync through two mechanisms.
- PADS Layout Link (real-time). With both programs open, Tools > Layout… in Logic brings up the Link dialog; click Send Netlist and Layout receives it immediately. Equivalent to KiCad’s “Update PCB from Schematic,” except you have to click it yourself.
- ECO (incremental update). For major changes, use Tools > Compare/ECO in Layout to generate an .eco diff and then import it; only the differences are updated and existing routing is preserved.
Across versions, for two-person collaboration, or for archiving, there’s also the file route: Logic exports an .asc netlist and you use File > Import in Layout.
2. The biggest hurdle: libraries come in a set of three
Coming from JLCEDA or KiCad, this is where people get stuck, so let’s be thorough about it.
JLCEDA’s “component” binds symbol, footprint, and 3D into a single cloud object; KiCad has two files, a symbol library and a footprint library, matched by name. PADS is more primitive, split into three layers.
Part Type (component type) ← what you actually place in the schematic
├── CAE Decal (schematic symbol) ← what that symbol looks like in the schematic
├── PCB Decal (footprint) ← the set of pads on the board
└── Electrical properties: Logic Family / Prefix / Gates / Pins / Attributes
Three key points.
- Changing the footprint means changing the Part Type. Editing the CAE Decal or PCB Decal file itself does nothing; you have to change this Part Type’s PCB Decals property and then run ECO to sync it to the PCB. Conversely, this is an advantage: one Part Type can carry several footprints at once. Place a CAP in the schematic, right-click Properties, and pick 0402 / 0603 / 0805 / 1206 from the dropdown—no need to create four components.
- The division of labor is rigid. CAE Decals can only be created in Logic’s Part Editor, PCB Decals only in Layout’s Decal Editor; Part Types can be created in either.
- Multi-gate devices are split up in Gates. Create one Part Type for an LM358, split Gates into A and B symbols, place it twice in the schematic, and the reference designators automatically become U1A / U1B while still sitting behind the same 8-pin footprint.
Another PADS specialty: power and ground are handled with hidden pins (Signal Pins). On a 14-pin IC with VCC on pin 14 and GND on pin 7, you can leave those two pins off the symbol and instead declare them under Electrical > Signal Pins in the Part Type; the netlist connects them automatically. The approach is very retro, but it’s widespread in parts converted from other vendors’ libraries—if you don’t recognize it, you’ll think the symbol is missing pins.
On disk, a library is a directory full of files with the same base name, distinguished by extension. Extensions vary by version; on 9.x you commonly see the set .p (Part Type), .c (CAE Decal), .d (PCB Decal), .l (Line), and in some environments .pt9 / .ld9 / .pd9 / .ln9—go by what you actually see in your own library directory. This doesn’t affect your understanding, but it has two direct consequences.
- Copying, backing up, or handing off a project—this group of files must travel together. Copy only the Part Type and the other person opens the project to a sea of “symbol not found.”
- The build order is PCB Decal first, then CAE Decal, and finally the Part Type binding; when saving, click Check Part. An error saying “Package has no gates” means you forgot to assign a symbol to a Gate.
There’s a shortcut when taking over an old project. Open their PCB, right-click Select Components to select all, then right-click Save to Library, check Select All for both Part Type and Decal, and the whole board’s components land in your own library—much faster than drawing from scratch.
Importing footprints from JLCEDA is not a smooth path: it exports Altium / KiCad formats that 9.3 can’t read, and even after conversion you must check pad sizes, origin, layer count, and pin-number order item by item. Redrawing an 0603 from the datasheet takes two minutes and is usually faster than repairing a converted footprint.
3. A few spots where the operating logic feels awkward
3.1 Modeless commands are the soul of PADS
Without touching menus, with the mouse over the canvas, you type on the keyboard and press Enter and the command executes. This is a habit handed down from the '90s; once you adapt, it’s much faster than digging through menus. Commands are case-insensitive, and most work with or without spaces.
| Input | Effect | Example |
| G nn | Design grid (snap) | G25 = 25 mil, G 0.635 = 0.635 mm |
| GD nn | Display grid (dot display density, not the same as snap) | GD50 |
| W nn | Line width | W30 = 30 mil, can be typed at any point mid-route |
| L n | Current layer | L1 top, L2 bottom |
| Z n / ZZ | Show only one layer / show all layers | Z1 shows only the top layer, ZZ shows all |
| PL n m | Routing layer pair (paired when switching layers) | PL 1 2 |
| V name | Select via type; the type must first be defined in Setup > Pad Stacks > Via | V STDRVIA |
| UMM / UM / UI | Switch units to mm / mil / inch; writing U MM with a space also works | UMM |
| S x y | Jump to absolute coordinates | S 1000 500 |
| SR dx dy | Offset relative to the current point | SR 200 0 |
| SS name | Search and select | SS R5, SS ‘U1’ |
| SO | Set origin | Define the datum when building a footprint |
| Q / QL | Quickly measure the distance between two points / the length of selected objects | Q |
| N net | Highlight the specified net; type again to cancel | N GND |
| PO | Show copper pour as outline only | Type it before editing traces to see the routing clearly |
| O | Display pads and traces as outlines | Reduce screen load |
| T | Transparent display mode | See bottom-layer traces |
| AD / AA / AO | Routing angle 45° / any angle / 90° | AD is the most common |
| DRP / DRW / DRI / DRO | Online DRC prevent / warn / ignore / off | DRP is best left always on |
| R | Refresh display (Ctrl+D also redraws; differs between versions) | R |
| I | Database integrity check | I |
You don’t need to memorize them all. Get G grid, W width, L layer, S find, Q measure, U unit, and V via down cold, and 80% of daily operations won’t require touching menus; keep the rest as a quick reference.
3.2 The key bindings don’t match—retrain these muscle memories first
| Function | JLCEDA habit | KiCad habit | PADS 9.3 |
| Confirm / place point | Left click | Left click | Spacebar is equivalent to left click |
| Context menu / cancel action | Right click | Right click | M is equivalent to right click |
| Rotate | Space or R | R | Ctrl+R |
| Flip to other side | Alt+F / F | F | Ctrl+F (mirror up/down: Ctrl+Shift+F) |
| Move | Drag | M | Ctrl+E, or select and drag directly |
| Drag-copy | Ctrl+drag | — | Ctrl+drag |
| Properties | Tab / double-click | E | Ctrl+Q, or double-click |
| Route / draw connection | Alt+W | X | F2 (routing in Layout, connection line in Logic) |
| Dynamic routing (push-and-shove) | — | — | F3 |
| Change layer while routing | Alt+T / click layer | V (place via) | F4 switches layer pair and auto-adds a via, or type L 3 |
| Place via while routing | Alt+V | V | Shift+left double-click, or right-click Add Via |
| End routing | Enter / Esc | Esc | Ctrl+left double-click, or M (M itself is the cancel action) |
| Change trace width | Shift+W | — | W 0.5 (modeless) |
| Undo | Ctrl+Z (essentially unlimited) | Ctrl+Z (unlimited) | Ctrl+Z (limited steps; can’t undo ECO or copper pour) |
| Fit all | K | Home | Home (board outline only: Ctrl+B) |
| Layer colors | Layer panel | Layer panel | Ctrl+Alt+C |
| Highlight net | Alt+H / Shift+H | ~ | Ctrl+H to highlight, Ctrl+U to cancel |
| Switch units | Q | — | UMM / UM / UI |
The ones most likely to trip you up are Space and M. In JLCEDA, Space rotates; in KiCad, Space starts placing a component; in PADS, Space is simply the left mouse button—carrying over old habits will cause a chain of misoperations. When routing it’s actually great: one hand on the mouse for direction, the other on Space to drop a point and M to cancel—you just have to hold it in for the first couple of days.
A note on M: in PADS it does double duty—popping up the context menu and canceling the current action are two sides of the same thing, which is why it can also serve as “end routing.”
3.3 Right-click works as a filter first
PADS’s right-click has two levels. Right-clicking on empty space brings up the selection filter (Select Anything / Select Traces / Select Pins / Select Components…); you first declare what type of object you want to select, then left-click it. Once an object is selected, right-clicking again brings up the operation menu (Move / Rotate 90 / Properties…). The thing that baffles newcomers most—“how do I delete a segment of trace?”—is answered by right-clicking, choosing Select Traces, then clicking.
The filter shortcut is Shift+S, faster than digging through the right-click menu.
3.4 The UI is modal, and ECO requires a license
- After entering Part Editor or Decal Editor, the main menu loses a chunk; many people think the software is broken, but you’re just still in editor mode—get out via File > Exit Part Editor (or Exit Decal Editor).
- In Layout, electrical operations such as adding connections, adding components, or renaming nets require first clicking the ECO icon on the toolbar to enter ECO mode; otherwise you can only move parts and draw board outlines. The classic symptom of forgetting to enter ECO is “why can’t I add a trace?”; conversely, staying in ECO mode all the time makes it easy to accidentally change nets—exit when you’re done.
3.5 Libraries and projects are separate
KiCad can stuff libraries into the project directory and take them along with it; JLCEDA has the concept of a project library. PADS libraries are independent—project files store only component references. Switch computers or send the project to a colleague without the library files and they’ll open the schematic to a wall of errors. This is the thing most often forgotten during handoff and archiving.
4. The complete flow for a two-layer board
Order matters; PADS insists on library before schematic, schematic before board.
Step 0 Environment setup (one-time). Create the library directory under a purely English path with no spaces, e.g. D:\PADS_LIB\mylib; installing under Program Files with spaces causes all sorts of mysterious problems. File > Library → Manage Lib List, add your own library and move it to the top; the library search order runs top to bottom, so putting yours first avoids name conflicts; keep the built-in ment_lib read-only and just Copy common parts out of it to modify. Setup > Layer Definition: set the electrical layer count to the target count, and at the same time set the non-electrical layers to the maximum, because footprints imported from elsewhere may carry information about higher layer numbers—if the layer count is insufficient, components will be lost on netlist import. Ctrl+Alt+C to give Top, Bottom, Silkscreen, and Solder Mask four distinct colors. UMM to switch to millimeters.
Step 1 Build the library. In Layout’s Tools > Decal Editor, draw the footprint: UMM, grid 0.05, place pads with Terminal; after placing the first of a row of same-size pads, right-click Step and Repeat to lay out the rest in one go; Tools > Pad Stacks to change sizes and drill (leave the drill blank for SMD pads); right-click Renumber Terminals to renumber pins; draw silkscreen on the Silkscreen Outline layer; SO to put the origin on pin 1 (the origin determines the placement rotation center and the SMT coordinates). When saving, choose to create a Part Type: on the General page choose Logic Family and reference prefix; on the Gates page assign a CAE Decal to each gate; on the Signal Pins page declare hidden power/ground pins; on the Attributes page fill in Value (resistors and capacitors must have it, otherwise it’s blank on the schematic); click Check Part and save once it’s clean. If the library already has something similar, Copy it, rename it, and adjust the parameters—faster than drawing from scratch.
Step 2 Schematic. In Logic, File > New and save as .sch; toolbar Add Part to place components, F2 to draw connections, Add Net Label to attach net names (same-name labels are the same net), place power and ground from the library as the corresponding Parts, and if reference designators get messy use Tools > Renumber; finally run ERC to check unconnected pins and single-ended nets, under Tools > ERC. 9.3 has no autosave—press Ctrl+S often.
Step 3 Send the netlist. First open Layout and create an empty board, then go back to Logic and click Send Netlist. All components will pile up at the origin—don’t panic; Tools > Disperse Components scatters them in one click.
Step 4 Board outline and placement. Draw a closed rectangle with the drawing tool’s 2D Line, select it and right-click Convert to Board Outline; Ctrl+E to move, Ctrl+R to rotate, Ctrl+F to flip, Ctrl+L to align after box-selecting, and holding Ctrl while dragging is drag-copy. Placement principles are exactly the experience you already have; only the grip changes.
Step 5 Layers and rules. Set inner power/ground layers as CAM Plane (full negative plane) or Split/Mixed (split power). Setup > Design Rules: set Default first; typical values for consumer electronics with 1 oz copper—clearance 6–8 mil, signal trace width 6–8 mil, via 12/24 mil, power traces sized by current (roughly 1 mm per 1 A on outer layers). Rules have four levels: Default → Class (net class) → Net → Pin Pair, with higher priority further down. Define differential pairs in Net Classes, then set clearance and width.
Step 6 Routing. F2 starts from the starting pad, F4 changes layer and auto-adds a via, Shift+left double-click adds a via manually, type W 0.5 mid-route to change width, AD locks 45°, Backspace backs up one segment, Ctrl+left double-click ends. Do high-speed and length-matching work in PADS Router—that’s where push-and-shove is complete. If routing gets messy, select the net and press Ctrl+M to minimize the ratsnest, then re-evaluate placement.
Step 7 Copper pour. Drawing toolbar Copper Pour: draw a polygon inset 0.3–0.5 mm from the board outline, double-click to set net GND and the thermal relief connection style, then right-click Flood to pour. After changing placement or routing you must re-Flood; PADS copper pour does not refresh automatically, and this is the habit that differs most from KiCad and JLCEDA—forget it and the copper and traces won’t match, a classic source of old PADS projects going wrong. Before editing traces, type PO to turn the copper into outlines and the screen immediately clears up.
Step 8 Verification. Tools > Verify Design, run Clearance, Connectivity, and Plane one by one. Don’t skip Connectivity; cases where the ratsnest looks connected but isn’t do exist. Errors are marked on the DRC Error layer; clear the markers and rerun after fixing.
Step 9 Generate production files. File > CAM, create a document per layer: n electrical layers Routing, plus two silkscreen, two solder mask, two paste, one drill drawing, and one NC drill—10 total for a two-layer board (n+8). For each, Customize to check layers, Preview, Run to generate .pho; drill is .drl. The output directory defaults to the CAM folder under the install directory—remember to change it to the project directory. SMT coordinates go through Pick and Place in File > CAM or CAM Plus. BOM comes from Logic’s Tools > Bill of Materials. Before sending to the fab, review once with CAM350 or the fab’s tool. For archiving, pack .sch, .pcb, the library folder, and the CAM output into one package—without the library, others opening the schematic get a wall of errors.
5. Pitfall list
| Symptom | Cause | Fix |
| Importing the netlist reports “footprint not found” | Library not added to the list or wrong order | Move it to the top in Manage Lib List and check it as available |
| Half the components missing after import | Design layer count lower than footprint layer count | Set non-electrical layers to max in Layer Definition |
| Check Part reports Package has no gates | Gate has no CAE Decal assigned | Add it under Part Information > Gates |
| Components have no value on the schematic | Value not filled in under Attributes | Fill it in |
| Power/ground pins missing from the symbol | Hidden pins are being used | Check Electrical > Signal Pins—they’re not missing |
| Changed the footprint but the PCB didn’t change | Only the PCB Decal was changed, not the Part Type | Change the Part Type’s PCB Decals, then run ECO |
| Copper pour doesn’t update after changes | Not re-poured | Right-click Flood, or Tools > Pour Manager |
| Trace width is wrong | Net / Class rules override Default | Check by priority Default → Class → Net |
| A menu is missing | Still in Part / Decal Editor mode | File > Exit Part Editor / Exit Decal Editor |
| Can’t add traces | Not in ECO mode | Click the ECO icon on the toolbar |
| Space rotated the component | Brought the JLCEDA habit along | In PADS Space is left-click confirm; rotate is Ctrl+R |
| Typing V STDRVIA does nothing | Via type not defined | First create the type in Setup > Pad Stacks > Via |
| Modeless commands do nothing | Chinese input method is active | Switch to an English input method |
| Undo can’t save you | ECO, copper pour, and similar operations aren’t undoable | Ctrl+S a copy before big moves; .pcb# / .sch# are autosaves—if it crashes, change the extension to recover |
| UI looks blurry | Old program isn’t high-DPI aware | exe properties → Compatibility → Change high DPI settings; try “System” first, then “System (Enhanced)” if still blurry, and “Application” if neither is ideal |
Two more lessons. First, pin numbers: they’re the ID card between schematic and PCB. CAE Decal pin numbers must correspond one-to-one with PCB Decal pad numbers; if nets don’t match after import, check the Part Type’s pin mapping first. Second, 3D viewing in the 9.3 era is an immature plug-in—don’t rely on it for interference checks; for mechanical fit, export STEP and hand it to the mechanical team.
6. How to practice in the first two weeks
- Days 1–2: get a minimal project running end to end. Take a small circuit—an LDO, two capacitors, an LED—and walk the whole flow: build the library, schematic, send netlist, placement, routing, copper pour, DRC, Gerber. The goal is really just knowing where each next step is, not drawing well.
- Days 3–5: drill modeless commands into muscle memory. Force yourself not to touch menus; cycle through G, GD, S, SR, SS, L, Z, W, Q, UMM. These days will be uncomfortable, but once past this hump PADS flows.
- Week 2: redraw a board you already know well. The circuit needs no thought; put all your attention on the tool.
- After that: switch to Router. Throw the same board into PADS Router and route it again to experience push-and-shove. Half of PADS’s value is in Router.
7. One-page cheat sheet
[Flow] Logic draw schematic → ERC (Tools>ERC) → Tools>Layout>Send Netlist → Layout receives
→ board outline (2D line → right-click Convert) → layers/rules (Setup)
→ placement (Ctrl+E/R/F) → routing (F2/F3/F4) → Copper Pour → Flood
→ Verify Design → CAM (n+8 documents, .pho/.drl) → BOM (Logic)
[Modeless] G grid GD display grid W width L layer Z layer display PL layer pair V via
UMM/UM/UI units S coordinate / SR relative / SS search SO origin Q measure
N highlight net PO copper outline O outline T transparent R refresh AD 45°
DRP/DRW/DRI/DRO four online DRC modes I integrity check
[Keys] Space = left click M = right click (incl. cancel) Ctrl+R rotate Ctrl+F flip
F2 route/connect F3 dynamic route F4 change layer Ctrl+E move Ctrl+Q properties
Ctrl+H highlight Ctrl+U cancel Ctrl+L align Ctrl+Alt+C colors
[Right-click] Empty right-click = selection filter (Shift+S) right-click on selection = operation menu ECO icon = change electrical
[Library] Part Type = CAE Decal (symbol) + PCB Decal (footprint) + pin mapping
A group of same-named files in a directory, extensions vary by version; hand off the whole group; manage via File>Library
[Sync] Schematic change → Send Netlist; PCB electrical change → ECO → back-annotate
Final notes
These are migration notes I organized for myself, left here for anyone else coming from JLCEDA or KiCad. Key bindings and menu paths follow the default English UI of 9.x; environments where bindings were changed or that use VX and later will differ—go by the real machine. Library file extensions vary the most between versions; don’t copy them blindly—look at what’s actually on your machine.
A few handy habits to close out. Before editing traces, type PO to glance at the copper outlines—saves a lot of repeated Flooding. Ctrl+drag to copy when placing parts in bulk. Don’t hunt through the schematic for a component—SS plus the reference designator gets you there in one step. Before releasing a board, run Flood and Verify once each, then hand it off.
If anything above is wrong, or you have better habits, feel free to add them below.
