What is the relationship between the resonant frequency and the cutoff frequency of an LC low-pass filter?
LC Low-Pass Filter: Transfer Function, Frequency Characteristics, and System Analysis
1. Transfer Function of the LC Filter
The transfer function of the LC filter is expressed as:
H(s) = \frac{1}{1 + LC s^2}
where L represents inductance and C represents capacitance (core components of the LC topology).
2. Bode Plot and Magnitude-Frequency Characteristic
To analyze the frequency-domain behavior (Bode plot), substitute the complex frequency s = j\omega (where j is the imaginary unit, \omega = 2\pi f is the angular frequency) into the transfer function:
H(j\omega) = \frac{1}{1 - LC \omega^2}
The magnitude-frequency characteristic (amplitude response) of the filter is:
|H(j\omega)| = \left| \frac{1}{1 - LC \omega^2} \right|
3. Characteristic Analysis at Resonant Frequency
The resonant frequency (natural frequency) of the LC circuit is defined as:
\omega_0 = \frac{1}{\sqrt{LC}}
(Note: The original text uses \omega_c to denote the resonant frequency; this is adjusted to the standard notation \omega_0 for consistency with electronic engineering terminology.)
At \omega = \omega_0 , the denominator of H(j\omega) equals 1 - LC \cdot \frac{1}{LC} = 0 , so the gain |H(j\omega_0)| \to \infty . This means the standalone LC filter design is impractical for most applications:
  • Insufficient damping amplifies interference at the resonant frequency.
  • In switching power supplies, parasitic parameters (from layout/wiring or component packaging) can trigger oscillations during switching transients.
  • PWM square waves (widely used in switching power supplies) contain all high-frequency harmonics via Fourier decomposition, which easily excite resonance in the LC filter.
4. Derivation of the Cutoff Frequency (-3dB Frequency)
The cutoff frequency (or -3dB frequency) is the frequency where the filter’s amplitude attenuates to \frac{1}{\sqrt{2}} (3dB below the DC gain). To calculate it, solve the equation:
\left| \frac{1}{1 - LC \omega^2} \right| = \frac{1}{\sqrt{2}}
Derivation Steps:
  1. Square both sides to eliminate the absolute value and square root:
\frac{1}{(1 - LC \omega^2)^2} = \frac{1}{2} \implies (1 - LC \omega^2)^2 = 2
  1. Take the square root (select the negative solution, as 1 - LC \omega^2 < 0 for the low-pass filter’s cutoff):
1 - LC \omega^2 = -\sqrt{2}
  1. Rearrange to solve for \omega :
LC \omega^2 = 1 + \sqrt{2} \implies \omega = \frac{1}{\sqrt{LC}} \cdot \sqrt{1 + \sqrt{2}}
Substitute \omega_0 = \frac{1}{\sqrt{LC}} , the cutoff frequency simplifies to:
\omega_{\text{cutoff}} \approx 1.554 \omega_0
5. Analogy to Undamped Second-Order System
The LC filter corresponds to an undamped second-order system (damping ratio \zeta = 0 ). The general transfer function of a second-order system is:
H(s) = \frac{\omega_n^2}{s^2 + 2\zeta \omega_n s + \omega_n^2}
For the LC filter:
  • \omega_n = \omega_0 = \frac{1}{\sqrt{LC}} (natural frequency),
  • \zeta = 0 (no damping).
Its step response exhibits constant-amplitude oscillation (sustained resonance), which further highlights the instability of the standalone LC filter.
To grasp this concept, we should interpret it through the logarithmic magnitude-frequency characteristic curve of the LC low-pass filter:
First, the transfer function of the filter is defined as:
H(s) = \frac{1}{LCs^2 + 1}
Its logarithmic magnitude-frequency characteristic curve exhibits the following behavior:
  • Initially, it appears as a horizontal line parallel to the abscissa (with a slope of 0 dB/decade, meaning no gain/loss).
  • A transition occurs at the resonant frequency \omega = \frac{1}{\sqrt{LC}} . Beyond this frequency, the curve rolls off with a slope of -40 dB/decade (steep attenuation of high frequencies).
The frequency corresponding to the -3 dB attenuation point on this curve is defined as the cutoff frequency. Calculating this cutoff frequency involves relatively complex steps; thus, if high precision is not required, the resonant frequency can be used as a reasonable approximation of the cutoff frequency.
From a physical perspective:
  • The resonant frequency of the LC filter refers to the frequency at which the inductor (L) and capacitor (C) oscillate in tandem, causing the circuit to present a purely resistive impedance characteristic (no reactive components dominate).
  • The cutoff frequency, by contrast, marks the specific frequency threshold where the LC filter begins to exert its filtering effect—i.e., the point at which high-frequency signals start to be significantly attenuated.
在理想的 LC 低通滤波器中,谐振频率与截止频率的数值是相同的,它们都使用同一个公式计算:
f_c = f_r = \frac{1}{2\pi\sqrt{LC}}
其中 L 为电感值,C 为电容值。
物理意义上的区别在于:
  • 截止频率( f_c )是滤波器通带与阻带的边界,通常定义为信号增益下降至‑3 dB 的频率点。
  • 谐振频率( f_r )是 LC 电路在无损耗时电抗相互抵消、出现共振的频率。
因此,尽管公式相同,截止频率描述的是滤波器的频率响应特性,而谐振频率描述的是电路本身的共振特性。在实际电路中,由于元件寄生参数(如串联电阻)的影响,两个频率可能会有微小偏差,但理论分析和设计时通常视作一致。
LC Low-Pass Filter: Core Relationship Between Resonant Frequency and Cutoff Frequency
As an electronic engineer, in scenarios like switching power supply output filtering and signal anti-interference, the resonant frequency (f_0) and cutoff frequency (f_c) of an LC low-pass filter are critical parameters—where f_0 is the inherent property of the LC circuit, and f_c defines the core filtering performance. These two are tightly linked through the damping factor (\zeta), with their relationship varying based on topology and load conditions. This article explores their relationship through definitions, mathematical derivations, and practical applications, balancing theoretical depth and engineering utility.
I. Basic Definitions: Understanding the Nature of the Two Frequencies
1. Resonant Frequency (f_0)—The “Natural Oscillation Frequency” of the LC Circuit
The resonant frequency is the oscillation frequency maintained by the LC circuit without external excitation, determined solely by inductance (L) and capacitance(C), independent of load or damping:
f_0 = \frac{1}{2\pi\sqrt{LC}}
  • Physical Significance: At this frequency, the capacitive reactance (X_C = 1/(2\pi fC)) equals the inductive reactance (X_L = 2\pi fL), making the circuit purely resistive. Energy periodically transfers between the inductor and capacitor.
  • Key Characteristics: For a series LC circuit, impedance is minimized (near 0) at resonance; for a parallel LC circuit (common in power supply filtering), impedance peaks at resonance, bypassing high-frequency signals.
2. Cutoff Frequency (f_c)—The “Transition Frequency” for Filtering Performance
The cutoff frequency (also called the -3dB frequency) is the frequency at which the output voltage amplitude attenuates to 1/\sqrt{2} of the input (50% power attenuation), marking the boundary between the “passband” and “stopband”:
  • Physical Significance: Signals below f_c pass with minimal attenuation, while signals above f_c are significantly suppressed.
  • Key Characteristics: f_c depends not only on L and C but also on the load resistor (R_L) and damping (a core feature of second-order or higher filters).
II. Core Relationship: Mathematical Derivation and the Impact of Damping Factor
An LC low-pass filter is a second-order system, where the relationship between f_c and f_0 is governed by the damping factor (\zeta). Here, we analyze the common “series inductor + parallel capacitor + load resistor” topology (typical for switching power supply output filtering) and derive the key formula.
1. Transfer Function of a Second-Order LC Low-Pass Filter
Assume the circuit: Input voltage V_{in} → Series inductor L → Parallel branch (capacitor C + load resistor R_L) → Output voltage V_{out} (voltage across the capacitor).
Through impedance analysis, the magnitude of the transfer function is:
|H(j\omega)| = \frac{1}{\sqrt{\left(1 - \left(\frac{\omega}{\omega_0}\right)^2\right)^2 + \left(2\zeta \cdot \frac{\omega}{\omega_0}\right)^2}}
Where:
  • \omega = 2\pi f (angular frequency), \omega_0 = 2\pi f_0 (resonant angular frequency);
  • Damping factor \zeta = \frac{1}{2R_L\sqrt{\frac{C}{L}}} (determined by R_L, L, and C, reflecting energy dissipation in the circuit).
2. Quantitative Relationship Between f_c and f_0
The cutoff frequency is defined as |H(j\omega_c)| = 1/\sqrt{2} (-3dB attenuation). Substituting into the magnitude formula yields:
f_c = f_0 \cdot \sqrt{1 - 2\zeta^2 + \sqrt{2(2\zeta^4 - 2\zeta^2 + 1)}}
This formula is the core conclusion. The relationship between f_c and f_0 varies significantly with \zeta. Below are analyses for three common engineering scenarios:
Damping Factor \zeta System State Relationship Between f_c and f_0 Magnitude-Frequency Characteristics Engineering Applications
\zeta = 1/\sqrt{2} \approx 0.707 Critically Damped (Butterworth) f_c = f_0 Maximally flat magnitude response, no resonance peak Switching power supply output filtering, precision signal processing (optimal choice)
\zeta < 0.707 Underdamped f_c > f_0 Obvious resonance peak (magnitude exceeds 0dB), signal overshoot Avoid use (increased power supply ripple, signal distortion)
\zeta > 0.707 Overdamped f_c < f_0 No resonance peak, but slower magnitude attenuation, poor transient response Low-frequency signal filtering (allows slow response)
\zeta \to 0 (no load) Ideal Undamped f_c \approx 1.55f_0 Extremely strong resonance peak (magnitude approaches infinity) Absolute avoidance (circuit oscillation, poor stability)
3. Key Validation: Butterworth Criterion (Engineering Priority)
When \zeta = 0.707 (Butterworth filter design criterion), substituting into the formula:
f_c = f_0 \cdot \sqrt{1 - 2\times(0.707)^2 + \sqrt{2(2\times(0.707)^4 - 2\times(0.707)^2 + 1)}} = f_0
Here, the cutoff frequency equals the resonant frequency. The magnitude response is maximally flat in the passband with no resonance peak, balancing filtering performance and transient response. This is the optimal design for LC filters in power supply outputs and ADC front-end signal filtering.
III. Engineering Design Practice: Leveraging the Relationship for LC Filter Optimization
Take switching power supply output filtering as an example (requirements: 12V output voltage, 1A–5A load current, ripple ≤50mV, cutoff frequency f_c = 1kHz). The design steps are:
1. Determine Core Parameters
  • Load resistance range: R_L = V_{out}/I_{out} → 2.4Ω (full load 5A) ~ 12Ω (light load 1A);
  • Design criterion: Use Butterworth (\zeta = 0.707), so f_c = f_0 = 1kHz.
2. Calculate L and C
From f_0 = 1/(2\pi\sqrt{LC}) and \zeta = 1/(2R_L\sqrt{C/L}), solve simultaneously:
  • Use full-load R_L = 2.4Ω (most stringent condition, minimum damping):
    0.707 = \frac{1}{2\times2.4\times\sqrt{C/L}} \implies \sqrt{\frac{C}{L}} = \frac{1}{2\times2.4\times0.707} \approx 0.297
  • From f_0 = 1kHz, \sqrt{LC} = 1/(2\pi\times1000) \approx 159\mu s;
  • Solving yields: L \approx 1.8mH, C \approx 130\mu F (practical selection: 2mH inductor + 100μF capacitor).
3. Validate Resonant and Cutoff Frequencies
  • Resonant frequency: f_0 = 1/(2\pi\sqrt{2mH\times100\mu F}) \approx 1.125kHz;
  • Cutoff frequency: With \zeta \approx 0.707, f_c \approx f_0 = 1.125kHz, meeting the design requirement (±10% tolerance acceptable).
IV. Common Misconceptions and Summary
1. Misconception Corrections
  • Misconception 1: “The cutoff frequency of an LC low-pass filter equals the resonant frequency”—Only valid when \zeta = 0.707, not for underdamped/overdamped cases;
  • Misconception 2: “Higher resonant frequency always improves filtering”—Resonant frequency must align with f_c; excessive f_0 weakens stopband attenuation, while insufficient f_0 affects passband signal transmission;
  • Misconception 3: “Ignoring load resistance’s impact on f_c”—Load variations alter \zeta, shifting f_c. Design must use the most stringent load (minimum R_L).
2. Key Summary
  1. Resonant frequency f_0 is an LC circuit’s inherent property (f_0 = 1/(2\pi\sqrt{LC})), while f_c is the filtering transition frequency (determined by L, C, and R_L);
  2. The two are linked via \zeta. Prioritize the Butterworth criterion (\zeta = 0.707) in engineering, where f_c = f_0 for optimal performance;
  3. Design must account for load resistance range to ensure \zeta remains near 0.707 across all loads, avoiding ripple or distortion from resonance peaks.
This analysis directly supports precise LC low-pass filter design in practical engineering scenarios like power supply filtering and signal anti-interference.
